[QGIS-Developer] Authentication seems broken in master
Andreas Neumann a.neumann at carto.net
Thu Nov 2 06:54:37 PDT 2017
Hi Alessandro,
Thank you for your reply.
I don't know what I need to do to fix the auth-db issues. I keep getting
tons of error messages like
Auth DB query exec failed()
for existing connections.
This is for access through the GUI, not through Python.
Also, when I try to create a new auth config entry, it doesn't know my
master password anymore and can't create a new one. Pretty broken
currently.
Does this mean that my auth-db is corrupt and that I need to remove it
and create a new one?
Thanks for your reply,
Andreas
On 2017-11-02 14:38, Alessandro Pasotti wrote:
> On Thu, Nov 2, 2017 at 2:19 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Same for me. Very annoying.
>> Bernhard please file a ticket and assign it to Alessandro or Luigi.
>> Thanks,
>> Andreas
> Hi,
> the API has changed and the singleton has been removed.
> Auth manager instance is now accessible through the QgsApplication as QgsApplication.authManager()
> Please file a ticket for filling the API break document that the lazy coder forgot to do (blame on him!).
> btw, the lazy coder did not forget to fill the API break document for the `get` removal, see
> https://qgis.org/api/api_break.html#qgis_api_break_3_0_QgsAuthManager
> On 2017-11-02 14:05, Bernhard Ströbl wrote:
>> Hi all,
>> I cannot convince freshly compiled current master 1ffc3fd to save an authentication database.
>> Furthermore the Python access to QgsAuthManager via QgsAuthManager.instance() seems broken, too:
>> "type object 'QgsAuthManager' has no attribute 'instance'"
>> Both already worked in a former version (compiled about 2 weeks ago)
>> any hints?
>> shall I file tickets?
>> regards
>> Bernhard
>> __________ Information from ESET Mail Security, version of virus signature database 16343 (20171102) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
> Alessandro Pasotti
> w3:   www.itopen.it [2]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
[2] http://www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171102/25930277/attachment-0001.html>
More information about the QGIS-Developer mailing list
