[QGIS-Developer] Authentication seems broken in master
Alessandro Pasotti apasotti at gmail.com
Thu Nov 2 07:04:54 PDT 2017
On Thu, Nov 2, 2017 at 2:54 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Alessandro,
> Thank you for your reply.
> I don't know what I need to do to fix the auth-db issues. I keep getting
> tons of error messages like
> Auth DB query exec failed()
> for existing connections.
> This is for access through the GUI, not through Python.
> Also, when I try to create a new auth config entry, it doesn't know my
> master password anymore and can't create a new one. Pretty broken currently.
> Does this mean that my auth-db is corrupt and that I need to remove it and
> create a new one?
I've honestly no idea: it is not broken for me, I'm using the auth manager
right now on master with no issues and the authmanager tests are all green
(and there are quite a few).
I suggest you to file a bug report with some more details that can help to
reproduce the issue.
Thanks!
Thanks for your reply,
> Andreas
> On 2017-11-02 14:38, Alessandro Pasotti wrote:
> On Thu, Nov 2, 2017 at 2:19 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Same for me. Very annoying.
>> Bernhard please file a ticket and assign it to Alessandro or Luigi.
>> Thanks,
>> Andreas
> Hi,
> the API has changed and the singleton has been removed.
> Auth manager instance is now accessible through the QgsApplication as
> QgsApplication.authManager()
> Please file a ticket for filling the API break document that the lazy
> coder forgot to do (blame on him!).
> btw, the lazy coder did not forget to fill the API break document for the
> `get` removal, see
> https://qgis.org/api/api_break.html#qgis_api_break_3_0_QgsAuthManager
> On 2017-11-02 14:05, Bernhard Ströbl wrote:
> Hi all,
> I cannot convince freshly compiled current master 1ffc3fd to save an
> authentication database.
> Furthermore the Python access to QgsAuthManager via
> QgsAuthManager.instance() seems broken, too:
> "type object 'QgsAuthManager' has no attribute 'instance'"
> Both already worked in a former version (compiled about 2 weeks ago)
> any hints?
> shall I file tickets?
> regards
> Bernhard
> __________ Information from ESET Mail Security, version of
> virus signature database 16343 (20171102) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3:   www.itopen.it
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171102/26e1cc34/attachment.html>
More information about the QGIS-Developer mailing list
