[QGIS-Developer] Authentication seems broken in master
Alessandro Pasotti
apasotti at gmail.com
Thu Nov 2 07:22:19 PDT 2017
Andreas,
Would you mind using the hub for bug reporting?
Also, please add all possible details, as I said, I cannot reproduce this
(and I've run literaly hundreds of manual tests on authentication lately).
Thanks
On Thu, Nov 2, 2017 at 3:18 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Alessandro,
> Already at the start of QGIS I get two times the error message:
> WARNING: Auth db query exec() FAILED
> This happens during startup of QGIS without any user interaction.
> I had a look at the permissions of $HOME/.qgis3/qgis-auth.db - and they
> seem fine to me.
> Perhaps, if I/we can fix this, the other subsequent error message go away
> as well?
> Thanks,
> Andreas
> On 2017-11-02 15:04, Alessandro Pasotti wrote:
> On Thu, Nov 2, 2017 at 2:54 PM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi Alessandro,
>> Thank you for your reply.
>> I don't know what I need to do to fix the auth-db issues. I keep getting
>> tons of error messages like
>> Auth DB query exec failed()
>> for existing connections.
>> This is for access through the GUI, not through Python.
>> Also, when I try to create a new auth config entry, it doesn't know my
>> master password anymore and can't create a new one. Pretty broken currently.
>> Does this mean that my auth-db is corrupt and that I need to remove it
>> and create a new one?
> I've honestly no idea: it is not broken for me, I'm using the auth manager
> right now on master with no issues and the authmanager tests are all green
> (and there are quite a few).
> I suggest you to file a bug report with some more details that can help to
> reproduce the issue.
> Thanks!
>> Thanks for your reply,
>> Andreas
>> On 2017-11-02 14:38, Alessandro Pasotti wrote:
>> On Thu, Nov 2, 2017 at 2:19 PM, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>> Same for me. Very annoying.
>>> Bernhard please file a ticket and assign it to Alessandro or Luigi.
>>> Thanks,
>>> Andreas
>> Hi,
>> the API has changed and the singleton has been removed.
>> Auth manager instance is now accessible through the QgsApplication as
>> QgsApplication.authManager()
>> Please file a ticket for filling the API break document that the lazy
>> coder forgot to do (blame on him!).
>> btw, the lazy coder did not forget to fill the API break document for the
>> `get` removal, see
>> https://qgis.org/api/api_break.html#qgis_api_break_3_0_QgsAuthManager
>> On 2017-11-02 14:05, Bernhard Ströbl wrote:
>> Hi all,
>> I cannot convince freshly compiled current master 1ffc3fd to save an
>> authentication database.
>> Furthermore the Python access to QgsAuthManager via
>> QgsAuthManager.instance() seems broken, too:
>> "type object 'QgsAuthManager' has no attribute 'instance'"
>> Both already worked in a former version (compiled about 2 weeks ago)
>> any hints?
>> shall I file tickets?
>> regards
>> Bernhard
>> __________ Information from ESET Mail Security, version of v
>> irus signature database 16343 (20171102) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alessandro Pasotti
>> w3: www.itopen.it
> Alessandro Pasotti
> w3: www.itopen.it
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171102/c8c40478/attachment-0001.html>
