[QGIS-Developer] Rendering of Icons
Peter King pking at linz.govt.nz
Mon Nov 13 14:13:49 PST 2017
Hi Calvin
here is the svg optimisation tool which Robert recommended to me,
https://github.com/RazrFalcon/svgcleaner-gui , and the online version
https://jakearchibald.github.io/svgomg/
Pete
On 14/11/17 10:32, Robert Szczepanek wrote:
> Hi Calvin,
> How to render sharp icons is described in my design guidelines
> (http://robert.szczepanek.pl/gis-icons-0.1/). It depends on objects
> (lines) location on grid at target resolution.
> Inkscape writes in SVG many additional tags. Our goal is to decrease
> SVG icon size, so final vector files are simply optimized by external
> tools.
> regards
> Robert
> W dniu 13.11.2017 o 21:46, C Hamilton pisze:
>> I was wondering how you turn the QGIS .svg icons into .png icons that
>> are used in the tool bars. I have been using Inkscape and the
>> resulting icons that I produce starting from the QGIS .svg files
>> don't seem to be as sharp and clear as what is distributed with QGIS.
>> The other thing I have found is that the QGIS .svg files are very
>> small. If I read them into Inkscape and save them back out they are
>> much larger.
>> Thanks,
>> Calvin
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
More information about the QGIS-Developer mailing list
