[QGIS-Developer] On the danger of static C++ objects
Even Rouault
even.rouault at spatialys.com
Wed Nov 15 14:58:09 PST 2017
There was a frequent crash in PyQgsServerWMS on Travis that I've hopefully fixed per
https://github.com/qgis/QGIS/commit/581d0d30ca89a213b1ba1a56a3fe2af5c896eacd
This is the opportunity to raise attention on the danger of using this pattern:
static SomeClass singletonInstance;
where ~SomeClass() does some non trivial work in its destructor, and in particular calling
other libraries (such as in the above mentionned case). Depending on the order into which
libraries are unloaded and objects destroyed, ~SomeClass() might call a function of a
library which has already been unloaded, leading to crash.
So I'd suggest rather using a pointer approach (which admitedly makes constructing the
singleton in a thread-safe way a bit harder), and explicitly deleting the singleton at
appropriate and explicit time.
Unless someone is aware of a better approach.
By the way, is there somewhere in the tree a developer guide where we can collect such
knowledge ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171115/58f9aa6b/attachment.html>
