[QGIS-Developer] Parse project grid LineSymbol properties
Tom Chadwin
tom.chadwin at nnpa.org.uk
Thu Nov 16 00:51:07 PST 2017
I'm retrieving the project grid line symbol properties in Python:
stroke = project.readEntry("Grid", "/LineSymbol", "")[0]
This gives me what I presume is a string of serialized XML:
<symbol alpha="1" clip_to_extent="1" type="line" name="line symbol">
<layer pass="0" class="SimpleLine" locked="0">
<prop k="capstyle" v="square"/>
<prop k="customdash" v="5;2"/>
<prop k="customdash_map_unit_scale" v="0,0,0,0,0,0"/>
<prop k="customdash_unit" v="MM"/>
<prop k="draw_inside_polygon" v="0"/>
<prop k="joinstyle" v="bevel"/>
<prop k="line_color" v="0,0,0,255"/>
<prop k="line_style" v="solid"/>
<prop k="line_width" v="0.26"/>
<prop k="line_width_unit" v="MM"/>
<prop k="offset" v="0"/>
<prop k="offset_map_unit_scale" v="0,0,0,0,0,0"/>
<prop k="offset_unit" v="MM"/>
<prop k="use_custom_dash" v="0"/>
<prop k="width_map_unit_scale" v="0,0,0,0,0,0"/>
</layer>
</symbol>
I already have a function which reads through the properties of a line
symbol, but it works with properties retrieved via
QgsSymbolLayer.properties().
How do I convert the XML into whatever format QgsSymbolLayer.properties()
returns (a QgsStringMap, whatever that might be)?
Thanks
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
