[QGIS-Developer] QGIS-Server on Windows with IIS - missing methods in dlls
Nathan Woodrow
madmanwoo at gmail.com
Fri Nov 17 00:49:55 PST 2017
Stefan,
I think you are looking at the wrong thread. cgywin is just for running
shell scripts etc in Dev builds scripts. We build with VS 2015
On Fri., 17 Nov. 2017, 19:22 Stefan Steiger, <Steiger at cor-management.ch>
wrote:
> Why not cygwin ? Because it doesn't produce Windows native executables ...
> https://stackoverflow.com/questions/27678988/run-cygwin-built-exe-in-windows-without-cygwins-environment
> Use MinGW + msys instead.
> Strange that this still needs to be said in 2017.
> This explains why qgis-server didn't run on my machine...
> -----Ursprüngliche Nachricht-----
> Von: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org
> <qgis-developer-bounces at lists.osgeo.org>] Im Auftrag von Jürgen E. Fischer
> Gesendet: Mittwoch, 15. November 2017 10:02
> An: qgis-developer at lists.osgeo.org
> Betreff: Re: [QGIS-Developer] Merging raster-save dialog change and
> Windows workflow
> Hi,
> On Wed, 15. Nov 2017 at 01:02:48 +0000, Tisham Dhar wrote:
> > 1) Checkout as standard on windows with git-bash (line endings are
> an
> > issue). Will have to try a fresh clone in WLS to see what
> difference
> > it makes
> Why not cygwin? That's what I use and recommend. WLS means WSL?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/22b8f8fd/attachment.html>
