[QGIS-Developer] QGIS-Server on Windows with IIS - missing methods in dlls
Stefan Steiger Steiger at cor-management.ch
Fri Nov 17 00:14:18 PST 2017
Why not cygwin ? Because it doesn't produce Windows native executables ...
https://stackoverflow.com/questions/27678988/run-cygwin-built-exe-in-windows-without-cygwins-environment
Use MinGW + msys instead.
Strange that this still needs to be said in 2017.
This explains why qgis-server didn't run on my machine...
-----Ursprüngliche Nachricht-----
Von: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Jürgen E. Fischer
Gesendet: Mittwoch, 15. November 2017 10:02
An: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org>
Betreff: Re: [QGIS-Developer] Merging raster-save dialog change and Windows workflow
On Wed, 15. Nov 2017 at 01:02:48 +0000, Tisham Dhar wrote:
> 1)      Checkout as standard on windows with git-bash (line endings are an
>         issue). Will have to try a fresh clone in WLS to see what difference
>         it makes
Why not cygwin?  That's what I use and recommend.   WLS means WSL?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/69acf337/attachment.html>
More information about the QGIS-Developer mailing list
