[QGIS-Developer] Qt4 Designer - custom widgets - Manjaro
Anjo Weichbrodt
anjo.weichbrodt at gmail.com
Mon Nov 20 01:18:51 PST 2017
Hi Denis,
before I read your message yesterday I deinstalled 2.18 and compiled and
installed 2.99 from AUR, again with the option -DWITH_CUSTOM_WIDGETS=TRUE.
And it worked. In this case Qt5 Designer contained the Qgs custom-widgets.
Wonderful!
I saw that on my system I have actually 2 folders containing access to
libqgis_customwidgets.so:
/lib64/qt5/plugins/designer/ and
/lib/qt5/plugins/designer/
My problem has been resolved using the version 2.99 of QGIS. Let me know if
it useful to dig further for why it didn't worked with 2.18.
Thanks,
Anjo
2017-11-19 18:41 GMT+01:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
> Hi Anjo,
> Can you look in the about menu, there is a plugin entry, see if qgis
> custom widgets are listed there as broken.
> If so, can you try
> ldd /lib64/qt4/plugins/designerlibqgis_customwidgets.so
> Cheers
> Denis
> Le dim. 19 nov. 2017 à 12:00, anjo.weichbrodt <anjo.weichbrodt at gmail.com>
> a écrit :
>> Hi Matthias,
>> libqgis_customwidgets.so seems to be in the right location.
>> [anjo at anjo-pc ~]$ cd /lib64/qt4/plugins/designer/
>> [anjo at anjo-pc designer]$ ls
>> libpyqt4.so libqt3supportwidgets.so
>> libqdeclarativeview.so libqwebview.so
>> libqgis_customwidgets.so libqwt_designer_plugin.so
>> libqgis_customwidgets.so.2.18.14 libqwt_polar_designer_plugin.so
>> libqscintillaplugin.so
>> Other suggestions?
>> Thanks,
>> Anjo
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-
>> f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171120/c59c5344/attachment.html>
