[QGIS-Developer] Qt4 Designer - custom widgets - Manjaro
Denis Rouzaud denis.rouzaud at gmail.com
Sun Nov 19 09:41:57 PST 2017
Hi Anjo,
Can you look in the about menu, there is a plugin entry, see if qgis custom
widgets are listed there as broken.
If so, can you try
ldd   /lib64/qt4/plugins/designerlibqgis_customwidgets.so
Cheers
Denis
Le dim. 19 nov. 2017 à 12:00, anjo.weichbrodt <anjo.weichbrodt at gmail.com> a
écrit :
> Hi Matthias,
> libqgis_customwidgets.so seems to be in the right location.
> [anjo at anjo-pc ~]$ cd  /lib64/qt4/plugins/designer/
> [anjo at anjo-pc designer]$ ls
> libpyqt4.so                       libqt3supportwidgets.so
> libqdeclarativeview.so            libqwebview.so
> libqgis_customwidgets.so          libqwt_designer_plugin.so
> libqgis_customwidgets.so.2.18.14  libqwt_polar_designer_plugin.so
> libqscintillaplugin.so
> Other suggestions?
> Thanks,
> Anjo
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171119/3d86ef16/attachment.html>
More information about the QGIS-Developer mailing list
