[QGIS-Developer] Refactor Fields: save and load mapping configuration
Andreas Neumann
a.neumann at carto.net
Thu Nov 23 04:35:37 PST 2017
Hi Régis,
I agree - it would be good to brainstorm what's missing to have an
FME-like ETL environment.
I see that you are coming to the Madeira dev meeting. Would be a good
opportunity for such discussions and then open the QEP in parallel (or
open it before and work on it).
BTW: refactor fields isn't such a bad name in my opinion. Perhaps we
could introduce aliases for algorithms - so that they could be found
more easily?
Greetings,
Andreas
On 2017-11-23 09:12, Régis Haubourg wrote:
> Hi Andreas,
> I don't have any answer to that particular question, but in many project we are working for, it becomes clear that we need to push processing to become an ETL, and the field mapping component is clearly a key feature.
> What do you think about opening a QEP and store in there all what's currently missing for a clean and easy workflow?
> We clearly will have some funders in 2018.
> I see :
> # Mapping field alg:
> - rename it to something more easy to find. What about "Field matcher" ?
> - automap fields using tolerant expression based on heuristics (unaccent, lowercase, soundhex or whatever, field order.. )
> - save and restore config.
> - Auto restore for same table names
> - And, the key for fame, a graphical component for field matching, because this is what we all want :)
> # database writer :
> - finely control all SQL options: drop table / recreate / truncate / insert / update with where clause
> - add rollback option to just try without commiting
> - return all database logs in details
> Opinions?
> Régis
> 2017-11-23 9:01 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> The refactor fields algorithm is potentially very powerful.
>> However, I do miss a way to save and load the configuration (or maybe I just haven't found it). I have layers with many fields and I am adding additional fields with expressions.
>> Every time I run it, I have to do the configuration again and again. Is there a way to save and load the mapping configuration? It would save me a lot of time!
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171123/ea676ddb/attachment-0001.html>
