[QGIS-Developer] Refactor Fields: save and load mapping configuration
Matthias Kuhn
matthias at opengis.ch
Thu Nov 23 04:42:01 PST 2017
this is awesome and something I have been trying to push towards at a
lot of meetings over the last year.
It reminds me a lot of this proposal by Arnaud Morvan, with the
technical details that are required to get all your wishes working:
https://github.com/qgis/QGIS-Enhancement-Proposals/issues/89
Cheers
Matthias
On 11/23/2017 01:35 PM, Andreas Neumann wrote:
> Hi Régis,
> I agree - it would be good to brainstorm what's missing to have an
> FME-like ETL environment.
> I see that you are coming to the Madeira dev meeting. Would be a good
> opportunity for such discussions and then open the QEP in parallel (or
> open it before and work on it).
> BTW: refactor fields isn't such a bad name in my opinion. Perhaps we
> could introduce aliases for algorithms - so that they could be found
> more easily?
> Greetings,
> Andreas
> On 2017-11-23 09:12, Régis Haubourg wrote:
>> Hi Andreas,
>> I don't have any answer to that particular question, but in many
>> project we are working for, it becomes clear that we need to push
>> processing to become an ETL, and the field mapping component is
>> clearly a key feature.
>> What do you think about opening a QEP and store in there all what's
>> currently missing for a clean and easy workflow?
>> We clearly will have some funders in 2018.
>> I see :
>> # Mapping field alg:
>> - rename it to something more easy to find. What about "Field matcher" ?
>> - automap fields using tolerant expression based on heuristics
>> (unaccent, lowercase, soundhex or whatever, field order.. )
>> - save and restore config.
>> - Auto restore for same table names
>> - And, the key for fame, a graphical component for field matching,
>> because this is what we all want :)
>> # database writer :
>> - finely control all SQL options: drop table / recreate / truncate /
>> insert / update with where clause
>> - add rollback option to just try without commiting
>> - return all database logs in details
>> Opinions?
>> Régis
>> 2017-11-23 9:01 GMT+01:00 Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>>:
>> Hi,
>> The refactor fields algorithm is potentially very powerful.
>> However, I do miss a way to save and load the configuration (or
>> maybe I just haven't found it). I have layers with many fields and
>> I am adding additional fields with expressions.
>> Every time I run it, I have to do the configuration again and
>> again. Is there a way to save and load the mapping configuration?
>> It would save me a lot of time!
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
