[QGIS-Developer] CRS for GeoJson Data
C Hamilton
adenaculture at gmail.com
Fri Nov 24 06:54:40 PST 2017
Given that the GeoJSON standard specifies WGS84 shouldn't that be the
default that QGIS uses when it saves a GeoJSON file? I guess there could be
an option that would allow legacy GeoJSON files. What would it take to have
QGIS always save WGS84 by default?
For now I am updating Lat Lon Tools to support GeoJSON points. For my
purposes I will stick by the standard and not worry about alternative CRS
GeoJSON files.
Calvin
On Wed, Nov 22, 2017 at 5:23 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 22 novembre 2017 15:08:08 CET Tom Chadwin wrote:
> > I remember irritated tweets from someone like Sean Gillies involved the
> spec
> > about how projected CRSes had no place in GeoJSON.
> The last year standardized version of GeoJSON, IETF RFC7946, mentions in
> https://tools.ietf.org/html/rfc7946#page-12
> The coordinate reference system for all GeoJSON coordinates is a
> geographic coordinate reference system, using the World Geodetic
> System 1984 (WGS 84) [...]
> Note: the use of alternative coordinate reference systems was
> specified in [GJ2008], but it has been removed from this version of
> the specification [...]
> Regarding OGR, it will support reading & writing GeoJSON files with any
> CRS. Unless that on the write side you specify RFC7946=YES as layer
> creation option, in which case automatic reprojection to WGS84 is done.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171124/8f58e835/attachment.html>
