[QGIS-Developer] all profile removed, still OWS connections, where stored?
Richard Duivenvoorde
rdmailings at duif.net
Sun Nov 26 03:29:03 PST 2017
Yep, 'default QGIS3' profile:
When I removed:
~/.local/share/QGIS
I still kept (or migrated??) all kind of settings
Found also this one:
~/.local/share/qgis_help/profiles/default
not sure if this is an old help relict, but if not it should be moved to
default profiles
Then I removed
~/.qgis2
thinking that stuff was silently imported/migrated from there.
Still found stuff in QGIS3
And even (without .qgis2) QGIS 2.18 saw all recent projects (without
previews though)...
Which made me think: ah on Linux there is also:
~/.config/QGIS/QGIS2.conf
~/.config/QGIS/QGIS3.conf
which (apparently) are imported too?
(note: on Windows this is in registry)
Then I removed all those, and finally I had a clean sheat \o/
THEN my 'Open Active Profile Folder' was working again!
Ah, bummer, just one time. After that it breaks again :-(
Nor sure if this is 'our' migration stuff, or Qt is doing all this?
But in my opinion we should not 'automagically' import all kind of
(corrupted/ing) settings into a fresh profile. I hoped to be able to
really get a fresh start when I removed the ~/.config/QGIS dir.
IF that folder is not available, we should ask the use I think if she
wants to migrate or not.
I also happened to bump onto:
Boundless' settings documentation:
https://connect.boundlessgeo.com/docs/desktop/1.1.0/system_admins/globalsettings.html
and an earlier plugin:
http://boundlessgeo.github.io/qgis-plugins-documentation/profiles/plugin.html
So there is already the notion of a 'global/corporate' style settings
file? Which you can (could?) point to by adding startup parameter:
--globalsettingsfile
Is it only me who still finds this all a little hidden/automagic?
Regards,
Richard
On 25-11-17 23:58, Nathan Woodrow wrote:
> Hey,
> All profiles or just the default one? Because settings migration will be
> bringing it over from 2 for the default.
> On Sun., 26 Nov. 2017, 1:11 am Richard Duivenvoorde,
> <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> Hi Devs,
> in my understanding all(!) settings and configuration is now moved to
> the profiles? So in my case:
> /home/richard/.local/share/QGIS
> isn't it?
> BUT if I remove that folder (= all profiles isn't it?), then I still
> have the connections I had in earlier work in my Data Browser widgets?
> (at the moment in my system the 'Open Profile folder' isn't working so I
> cannot check the profile folder settings...)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
