[QGIS-Developer] QGIS crashes when installing plugin created with the plugin builder
Anjo Weichbrodt anjo.weichbrodt at gmail.com
Sun Nov 26 07:09:50 PST 2017
when I want to install a plugin created with the plugin builder QGIS
crashes.
resources.qrc is compiled.
The out put in the terminal is:
[anjo at anjo-pc ~]$ qgis-git
using qt5ct plugin
D-Bus global menu: no
D-Bus system tray: no
WARNING: Auth db query exec() FAILED
Warning: libpng warning: iCCP: known incorrect sRGB profile
QGIS died on signal 11Aborted (core dumped)
I run QGIS 2.99 on Manjaro linux414
Thanks,
Anjo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171126/52ea42c0/attachment.html>
More information about the QGIS-Developer mailing list
