[QGIS-Developer] Processing modeler GUI unusable in KDE / Plasma
Andreas Neumann a.neumann at carto.net
Wed Nov 29 23:37:04 PST 2017
Hi Nyall,
I reverted 5dce8edb
and built with custom widgets enabled.
Unfortunately, still the same problem.
Thanks,
Andreas
On 30.11.2017 08:09, Nyall Dawson wrote:
> On 30 November 2017 at 16:39, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi Mathieu,
>> Thanks for your efforts! I just tested it - unfortunately, your commit does
>> not solve my issue.
>> I also tested with a new virgin user profile to make sure there isn't some
>> old setting causing the troubles.
>> Custom widgets support is also not enabled.
> Can you try:
> - revert https://github.com/qgis/QGIS/commit/5dce8edb
> - build with custom widgets enabled and installed
> I want to rule out the custom widgets, and I suspect just switching
> them off in the build isn't enough to clean up the remnants of them.
> Nyall
More information about the QGIS-Developer mailing list
