[QGIS-Developer] Processing modeler GUI unusable in KDE / Plasma
Etienne Trimaille
etienne.trimaille at gmail.com
Thu Nov 30 00:02:15 PST 2017
I got the problem too for many months even if it was disabled in the cmake.
I needed to remove the qgis_customwidgets.py in the site-package folder of
Python
Maybe a `locate qgis_customwidgets.py` might help?
2017-11-30 8:37 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Nyall,
> I reverted 5dce8edb
> and built with custom widgets enabled.
> Unfortunately, still the same problem.
> Thanks,
> Andreas
> On 30.11.2017 08:09, Nyall Dawson wrote:
>> On 30 November 2017 at 16:39, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>> Hi Mathieu,
>>> Thanks for your efforts! I just tested it - unfortunately, your commit
>>> does
>>> not solve my issue.
>>> I also tested with a new virgin user profile to make sure there isn't
>>> some
>>> old setting causing the troubles.
>>> Custom widgets support is also not enabled.
>> Can you try:
>> - revert https://github.com/qgis/QGIS/commit/5dce8edb
>> - build with custom widgets enabled and installed
>> I want to rule out the custom widgets, and I suspect just switching
>> them off in the build isn't enough to clean up the remnants of them.
>> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171130/c7e99b2f/attachment.html>
