[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
Stéphane Henriod
stephanebek at gmail.com
Fri Oct 6 23:45:43 PDT 2017
Hi James!
Just to know if you had a chance to look at this and if you need some help
withe testing or whatever!
THanks
Stéphane
Le vendredi 29 septembre 2017, James Shaeffer <james at shaeffer.co> a écrit :
> I'll stab at fixing this.
> James Shaeffer
> On Thu, Sep 28, 2017 at 09:55:14PM +0600, Stéphane Henriod wrote:
> > Hi all
> > just trying one last time to get attention on this bug :-)
> > The bug is still present on the last 2.99
> > As usual, I apologize for complaining while not being able to take care
> of
> > it myself...
> > Easiest way to understand what is currently wrong is this screencast:
> > https://vimeo.com/219467091
> > With my little understanding, I would assume that the correction of this
> > bug is not a "big thing"? But maybe I am overlooking something
> > Thanks!
> > Stéphane
> > Le mercredi 21 juin 2017, Stéphane Henriod <stephanebek at gmail.com
> <javascript:;>> a écrit :
> > > Hi all
> > > Apparently, this has been confirmed as a bug. Is anyone willing / able
> to
> > > take care of it?
> > > Thanks a lot and cheers
> > > Stéphane (who really feels sorry to raise such questions, while not
> being
> > > able himself to actively contribute to the resolution of such bugs)
> > > Le jeudi 1 juin 2017, Stéphane Henriod <stephanebek at gmail.com
> <javascript:;>
> > > <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com <javascript:;>');>>
> a écrit :
> > >> Hi again
> > >> in doubt, I have opened a ticket here: https://issues.qgis.org/
> > >> issues/16649
> > >> Cheers
> > >> Stéphane
> > >> Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com
> > >>> PS: screencast to better explain the issue:
> > >>>> Hi
> > >>>> I am testing the layer styling panel (shortcut F7) with the latest
> > >>>> Nightly build on the Ubuntu repositories.
> > >>>> By default, the NoData value is -9999. If I add "10" as additional
> > >>>> NoData value, nothing happens.
> > >>>> If I do the same in the layer properties, then the expected behavior
> > >>>> happens: all pixels with value "10" are not rendered.
> > >>>> So it seems that the manually added NoData values in the Layer
> Styling
> > >>>> Panel are not considered.
> > >>>> Can someone else replicate this problem? Should I open a ticket?
> > >>>> Cheers
> > >>>> Stéphane
> > >>>> “When you travel, remember that a foreign country is not designed to
> > >>>> make you comfortable. It is designed to make its own people
> comfortable."
> > >>>> -- Clifton Fadiman
> comfortable."
> > >>> -- Clifton Fadiman
> make
> > >> you comfortable. It is designed to make its own people comfortable."
> > >> Clifton Fadiman
> make
> > > you comfortable. It is designed to make its own people comfortable." --
> > > Clifton Fadiman
> > “When you travel, remember that a foreign country is not designed to make
> > Clifton Fadiman
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org <javascript:;>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171007/565c1a52/attachment.html>
