[QGIS-Developer] QGIS master, Qt Creator 4.4.1 and Qt 5.9
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Thu Oct 26 03:56:04 PDT 2017
I experienced similar behavior. I have updated to CMake 3.9.4 and QtCreator
4.4.1 and it now works nicely.
Kind regards,
Peter
On Thu, Oct 26, 2017 at 12:03 PM, G. Allegri <giohappy at gmail.com> wrote:
> In the past I could easily use Qt Creator to open the QGIS CmakeLists as a
> project and navigate sources and headers inside the editor.
> Today I've setup a fresh Qt Creator (latest with Qt 5.9). While it can
> open CmakeLists as usual and configure it, the editor shows only the
> CmakeLists file but note the src files tree.
> I know this isn't strictly related to QGIS but given that Qt Creator is
> one of the preferred options to build/debug QGIS, I wondered if anyone else
> had the same problem and if you have suggestions to setup the environment.
> Thanks,
> giovanni
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171026/a8cce6a7/attachment.html>
