[QGIS-Developer] QGIS master, Qt Creator 4.4.1 and Qt 5.9
    G. Allegri
    giohappy at gmail.com
    Thu Oct 26 03:59:28 PDT 2017
Thanks Peter, i will try updateing CMale.
2017-10-26 12:56 GMT+02:00 Peter Petrik <peter.petrik at lutraconsulting.co.uk>
> Hi,
> I experienced similar behavior. I have updated to CMake 3.9.4 and
> QtCreator 4.4.1 and it now works nicely.
> Kind regards,
> Peter
> On Thu, Oct 26, 2017 at 12:03 PM, G. Allegri <giohappy at gmail.com> wrote:
>> In the past I could easily use Qt Creator to open the QGIS CmakeLists as
>> a project and navigate sources and headers inside the editor.
>> Today I've setup a fresh Qt Creator (latest with Qt 5.9). While it can
>> open CmakeLists as usual and configure it, the editor shows only the
>> CmakeLists file but note the src files tree.
>> I know this isn't strictly related to QGIS but given that Qt Creator is
>> one of the preferred options to build/debug QGIS, I wondered if anyone else
>> had the same problem and if you have suggestions to setup the environment.
>> Thanks,
>> giovanni
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171026/1b61861a/attachment.html>
