[QGIS-Developer] QGIS master, Qt Creator 4.4.1 and Qt 5.9
G. Allegri
giohappy at gmail.com
Thu Oct 26 09:41:09 PDT 2017
No way. I've just tested with cmake 3.10. I fear there's something wrong
with Qt, because my build dir contains only moc files with a .cpp_parametes
extension. No *.cpp and no *.h :(
giovanni
2017-10-26 12:59 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> Thanks Peter, i will try updateing CMale.
> 2017-10-26 12:56 GMT+02:00 Peter Petrik <peter.petrik at lutraconsulting.
> co.uk>:
>> Hi,
>> I experienced similar behavior. I have updated to CMake 3.9.4 and
>> QtCreator 4.4.1 and it now works nicely.
>> Kind regards,
>> Peter
>> On Thu, Oct 26, 2017 at 12:03 PM, G. Allegri <giohappy at gmail.com> wrote:
>>> In the past I could easily use Qt Creator to open the QGIS CmakeLists as
>>> a project and navigate sources and headers inside the editor.
>>> Today I've setup a fresh Qt Creator (latest with Qt 5.9). While it can
>>> open CmakeLists as usual and configure it, the editor shows only the
>>> CmakeLists file but note the src files tree.
>>> I know this isn't strictly related to QGIS but given that Qt Creator is
>>> one of the preferred options to build/debug QGIS, I wondered if anyone else
>>> had the same problem and if you have suggestions to setup the environment.
>>> Thanks,
>>> giovanni
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171026/5f2d3428/attachment.html>
