[QGIS-Developer] QGIS master, Qt Creator 4.4.1 and Qt 5.9
G. Allegri giohappy at gmail.com
Thu Oct 26 10:12:11 PDT 2017
I confirm that upgrading solved the problem, thanks Peter!
I needed to tell QtCreator kit to use the upgraded version...
giovanni
2017-10-26 18:41 GMT+02:00 G. Allegri <giohappy at gmail.com>:
> No way. I've just tested with cmake 3.10. I fear there's something wrong
> with Qt, because my build dir contains only moc files with a .cpp_parametes
> extension. No *.cpp and no *.h :(
> giovanni
> 2017-10-26 12:59 GMT+02:00 G. Allegri <giohappy at gmail.com>:
>> Thanks Peter, i will try updateing CMale.
>> 2017-10-26 12:56 GMT+02:00 Peter Petrik <peter.petrik at lutraconsulting.
>> co.uk>:
>>> Hi,
>>> I experienced similar behavior. I have updated to CMake 3.9.4 and
>>> QtCreator 4.4.1 and it now works nicely.
>>> Kind regards,
>>> Peter
>>> On Thu, Oct 26, 2017 at 12:03 PM, G. Allegri <giohappy at gmail.com> wrote:
>>>> In the past I could easily use Qt Creator to open the QGIS CmakeLists
>>>> as a project and navigate sources and headers inside the editor.
>>>> Today I've setup a fresh Qt Creator (latest with Qt 5.9). While it can
>>>> open CmakeLists as usual and configure it, the editor shows only the
>>>> CmakeLists file but note the src files tree.
>>>> I know this isn't strictly related to QGIS but given that Qt Creator is
>>>> one of the preferred options to build/debug QGIS, I wondered if anyone else
>>>> had the same problem and if you have suggestions to setup the environment.
>>>> Thanks,
>>>> giovanni
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171026/ae36ee07/attachment-0001.html>
More information about the QGIS-Developer mailing list
