[QGIS-Developer] Standalone and OSGeo4W installers: icons and folder on desktop
Jürgen E. Fischer
jef at norbit.de
Mon Sep 25 23:56:12 PDT 2017
Hi Tom,
On Mon, 25. Sep 2017 at 06:32:37 -0700, Tom Chadwin wrote:
> - installers should not add things to a user's desktop without permission
> (at least, certainly no more than a single application icon, and ideally not
> even that)
In now creates a OSGeo4W folder and points postinstall batch files to it via
OSGEO4W_DESKTOP - but not all OSGeo4W packages respect that (eg. QGIS does &
SAGA do, GRASS doesn't). There also OSGEO4W_DESKTOP_LINKS that tells
postinstall batches whether or not they should create desktop links at all.
> However, I continue to use the OSGeo4W installer, and I still get the folder
> on my desktop (its name is a URL-encoded form of
> http://download.osgeo.org/osgeo4w). I delete it each time, and each time I
> run Setup again, it is recreated.
> Is this because the installer has saved some config for my setup? I can
> check by trying to uninstall fully and start again, but I just thought I'd
> check. Do both the standalone and OSGeo4W installers now leave the desktop
> alone?
Check last-cache in %OSGEO4W_ROOT%/etc/setup/setup.rc
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170926/7326e269/attachment.sig>
