[QGIS-Developer] Struggling with QGIS Server 3 on a Ubuntu machine, installed from repositories
David Marteau dmarteau at 3liz.com
Fri Apr 20 07:58:18 PDT 2018
Try to activate log at info level. When the server start, you should have the following lines:
Checking /usr/lib/qgis/server for native services modules"
"Loading native module /usr/lib/qgis/server/libdummy.so"
Adding service SampleService 1.0
"Loading native module /usr/lib/qgis/server/libwcs.so"
Adding service WCS 1.0.0
"Loading native module /usr/lib/qgis/server/libwfs.so"
Adding service WFS 1.1.0
"Loading native module /usr/lib/qgis/server/libwms.so"
Adding service WMS 1.3.0
Initializing server modules from  "/usr/lib/qgis/server"
David
> Le 20 avr. 2018 à 16:25, Giovanni Manghi <giovanni.manghi at gmail.com> a écrit :
> Hi all,
> I'm quite familiar with the installation (on both Linux and Windows)
> and use of QGIS Server 2.* and in the past days I started to have a
> look also to version 3.
> I was able to test on Windows, but I'm struggling on Linux (Ubuntu
> 16.04) after having installed it from the QGIS repos.
> A request like
> http://localhost/cgi-bin/qgis_mapserv.fcgi?MAP=/path/to/project.qgs&SERVICE=WMS&REQUEST=GetCapabilities
> always return "Service unknown or unsupported".
> From the CLI
> "QUERY_STRING="SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/path/to/project.qgs"
> /usr/lib/cgi-bin/qgis_mapserv.fcgi
> it seems to return the capabilities but ends always with
> <ServiceException code="Service configuration error">Service unknown
> or unsupported</ServiceException>
> In logs I can see messages like
> "Service WMS is not registered"
> Downgrading to 2.18 and making the same requests works as expected.
> Anyone has an hint for me?
> thanks in advance
> -- Giovanni --
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
