[QGIS-Developer] Struggling with QGIS Server 3 on a Ubuntu machine, installed from repositories
Giovanni Manghi
giovanni.manghi at gmail.com
Fri Apr 20 08:31:35 PDT 2018
Thanks,
Alessandro pointed me to the problem/fix
https://github.com/qgis/QGIS/pull/6502
(note, for me worked by installing master, not setting the environment
variable on 3.0.1)
thanks again
cheers!
-- G --
On Fri, Apr 20, 2018 at 3:58 PM, David Marteau <dmarteau at 3liz.com> wrote:
> Hi,
> Try to activate log at info level. When the server start, you should have the following lines:
> Checking /usr/lib/qgis/server for native services modules"
> "Loading native module /usr/lib/qgis/server/libdummy.so"
> Adding service SampleService 1.0
> "Loading native module /usr/lib/qgis/server/libwcs.so"
> Adding service WCS 1.0.0
> "Loading native module /usr/lib/qgis/server/libwfs.so"
> Adding service WFS 1.1.0
> "Loading native module /usr/lib/qgis/server/libwms.so"
> Adding service WMS 1.3.0
> Initializing server modules from "/usr/lib/qgis/server"
> David
>> Le 20 avr. 2018 à 16:25, Giovanni Manghi <giovanni.manghi at gmail.com> a écrit :
>> Hi all,
>> I'm quite familiar with the installation (on both Linux and Windows)
>> and use of QGIS Server 2.* and in the past days I started to have a
>> look also to version 3.
>> I was able to test on Windows, but I'm struggling on Linux (Ubuntu
>> 16.04) after having installed it from the QGIS repos.
>> A request like
>> http://localhost/cgi-bin/qgis_mapserv.fcgi?MAP=/path/to/project.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>> always return "Service unknown or unsupported".
>> From the CLI
>> "QUERY_STRING="SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/path/to/project.qgs"
>> /usr/lib/cgi-bin/qgis_mapserv.fcgi
>> it seems to return the capabilities but ends always with
>> <ServiceException code="Service configuration error">Service unknown
>> or unsupported</ServiceException>
>> In logs I can see messages like
>> "Service WMS is not registered"
>> Downgrading to 2.18 and making the same requests works as expected.
>> Anyone has an hint for me?
>> thanks in advance
>> -- Giovanni --
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
