[QGIS-Developer] Issue running processing model from Python
Nyall Dawson
nyall.dawson at gmail.com
Thu Apr 26 20:01:10 PDT 2018
On 26 April 2018 at 17:14, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Issue solved - turned out that the layer in the project file was renamed (by
> a colleague) and hence processing could not find the feature source. All
> works fine now. Silly me!
> However, the processing error message was really misleading and had no
> indication that it could not find the layer. Nyall is going to fix the error
> message - thanks!
Hi Andreas,
Should be fixed by https://github.com/qgis/QGIS/pull/6874 . I'd
greatly value a test of that branch with the invalid project/model
combination to confirm that you get a helpful error message.
Nyall
> Sorry about the noise - it is a classic "beginners mistake" ;-)
> Andreas
> On 2018-04-25 12:19, Tom Chadwin wrote:
> Sorry, not having worked with models, I don't know. Only thing I wonder is
> whether it is a problem to have colons in a dictionary key
> (native:orderbyexpression_1:Ausgabedatei).
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
