[QGIS-Developer] Processing Help system
    matteo
    matteo.ghetta at gmail.com
    Fri Feb  9 02:21:14 PST 2018
Hey,
> yes, but I think we first have to rename the rst files like:
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/user_manual/processing_algs/qgis/vector_analysis_tools.rst
> to
> https://github.com/qgis/QGIS-Documentation/blob/master/source/docs/user_manual/processing_algs/qgis/vectoranalysis.rst
> so the output html name becomes 'vectoranalysis.html'. Apparently
> filenames earlier where chosen for readability, but we now use the
> 'groupid' (looking at Nyalls pull
> https://github.com/qgis/QGIS/pull/6298/commits/2d1e9188f18c40028b5501fe4c719808e8e20800)
yes, and this is an "easy" fix, just a couple of renamings
> And THEN we need to make sure the section names/headers indeed are the
> same as generated by the helpurl code, so the anchor is ok:
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectoranalysis.html#nearestneighbouranalysis
> So as Nyall is saying: using the algorithm id instead of the name.
while this is a not-so-small work, but easy to do it.
The only thing I'm a little concerned is readability of the final html
file.
Changing the name of the alrotihm/section from Nearest neighbour
analysis to nearestneighbouranalysis will bring us to have a
concatenated name for all algorithms, right?
I'm definitely not a sphinx guru, but is there the change to have a kind
of :meta: tag before each section and use this :meta: to build the URL?
Thanks Richard for the feedback
Matteo
