[QGIS-Developer] Last call for switching to github issue tracker
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Jan 12 13:41:48 PST 2018
For me as a simple user, the main obstacle of posting issues in redmine
is, that I fear to produce a duplicate, cause I didn't even learn over the
years how to efficiently track an issue down if it already exists.
No idea if github or any other solution is better, but redmine just sucks.
My 2 cents,
Bernd
Am 12.01.2018, 16:30 Uhr, schrieb Régis Haubourg
<regis.haubourg at gmail.com>:
> Hi all,+1 too.My main concern is that I now fail to search efficiently
> for redmine issues, because there are so many now. And this leads to
> >duplicates, or even worst, no declaring the issue because the process
> is too long.Github issues are very well indexed by google, which doesn't
> seem to be the case for redmine. (but this probably can be improved -
> >not sure how)
> Régis
> 2018-01-12 16:06 GMT+01:00 Jorge Gustavo Rocha <jgr at di.uminho.pt>:
>> Hi,
>> Good point, Denis!
>> Mathias already have done a lot to support the migration.
>> I volunteer to help on this task.
>> Regards,
>> Jorge Gustavo
>> On 12-01-2018 14:49, Matthias Kuhn wrote:
>>> On 01/12/2018 03:31 PM, Andreas Neumann wrote:
>>>> Hi,
>>>> I think the biggest question: who does all the work to migrate from
>>>> Redmine to Github while not loosing all our history?
>>> I started working on it some time ago and thought it looked quite
>>> promising. I stopped the work because of lack of conviction that
>>> there's
>>> a perspective for this.
>>>> And I don't think that Redmine is so bad usability wise. I agree, the
>>>> UI is not as sexy as Github, but it does its job well. It is much more
>>>> powerful for finding and filtering. The issues we had with the slow
>>>> performance was fixed when moving to a new Machine at Hetzner. The
>>>> main argument for github is in my opinion not ease of use - but the
>>>> integration with the code base - that is definitely a strength of
>>>> github issue reporting.
>>> Agreed, it's better than before.
>>> Because no more mantra, usable performance.
>>> On the other hand I don't prefer it's search and filtering options.
>>>> To undermine that github is not easy to use for non-dev users: last
>>>> Wednesday at the Swiss QGIS user meeting I was in the meeting for
>>>> QWC2. Users had no idea at all how Github works and could be used for
>>>> issue reporting. One had to explain it to them and teach them how to
>>>> use it. To assume that using github is self-explanatory for non-tech
>>>> users is a wrong assumption.
>>> I wouldn't claim that for either of the two platforms. There's a
>>> learning curve for both. Myself, I happen to meanwhile embrace markdown
>>> but struggle with the redmine syntax. Not because it's worse, just
>>> because I am too lazy to learn another one.
>>> Matthias
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> J. Gustavo
>> Jorge Gustavo Rocha
>> Departamento de Informática
>> Universidade do Minho
>> 4710-057 Braga
>> Tel: +351 253604480
>> Fax: +351 253604471
>> Móvel: +351 910333888
>> skype: nabocudnosor
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180112/a1b18c2f/attachment.html>
More information about the QGIS-Developer mailing list
