[QGIS-Developer] QEP: Projects in PostgreSQL
    Nathan Woodrow
    madmanwoo at gmail.com
    Tue Mar 20 05:31:27 PDT 2018
> this is always a huge issue with us since we work a lot in areas with very
> poor or no internet connection thus projects have to be loaded on our
> personal computers or external hardrives.
> also when you give a session to a client you always have to go into the
> project file and change the directory names.
Hey Syd,
QGIS has the option (on by default) to save as everything as relative paths
which is better to make projects portable
- Nathan.
On Tue, Mar 20, 2018 at 10:17 PM, Syd Visser <sydv at sjgeophysics.com> wrote:
> Martin
> a general comment on
> “All references to files will be saved as absolute paths “
> why does things have to be absolute path especially if you eventually will
> design for Geopackage that is suppose to simplify portability
> can the Path not be divided into two separate names
> 1) one that is easily changed like a computer home directory which changes
> depending on computer used
> 2) project and all of its sub-directories that should not change
> QGIS is not the only program that has this issue and i never quite
> understood why it was done this way maybe there is a explanation besides
> its simpler for programers.
> thanks
> Syd
> *Syd (Sipke) Visser, P.Geo.*
> President, Snr. Geophysicist/Geologist
> Tel: 1 (604) 582-1100
> Cell: 1 (604) 813-1440
> www.sjgeophysics.com
> <http://www.sjgeophysics.com>
> On 2018-03-19 07:09 AM, Martin Dobias wrote:
> Hi everyone
> Here is a new proposal to add support for storage of QGIS projects
> inside PostgreSQL (and possibly in other backends in the future):
> https://github.com/qgis/QGIS-Enhancement-Proposals/issues/118
> Any comments would be highly appreciated!
> Cheers
> Martin
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180320/6e4dfe58/attachment.html>
