[QGIS-Developer] wfs response paging
Jeremy Palmer palmerjnz at gmail.com
Tue May 1 12:25:52 PDT 2018
Hi Clayton,
On Wed, May 2, 2018 at 4:56 AM, Clayton Steneroden <
claytonsteneroden at planitgeo.com> wrote:
> I am testing a wfs (in development) against qgis and wanting to know if
> anyone can cue me in as to whether response paging should just work (qgis
> v3, wfs v2) when you add a layer exceeding the initial points loaded, or if
> you need other techniques to load all features from a wfs into qgis as a
> layer.  I see posts over past years on earlier versions that say response
> paging does not work in QGIS, one should instead change settings so the
> layer loads new points based on the bbox, things like that.
Yes from QGIS 2.18 WFS paging should work with WFS 2.0 services. Give QGIS
2.18 to ensure it works with your service. Note QGIS 3.0 has a few WFS
issues and bugs that need to be resolved, so I don't recommending using
that version yet.
Cheers
Jeremy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180502/4862dec1/attachment.html>
More information about the QGIS-Developer mailing list
