[QGIS-Developer] wfs response paging
    Clayton Steneroden
    claytonsteneroden at planitgeo.com
    Tue May  1 17:03:42 PDT 2018
Great, glad I asked, I was testing on 2.16 and 3 - thank you.
*Clayton Steneroden*
p:720.988.2046 m:720-984-8624
On Tue, May 1, 2018 at 1:25 PM, Jeremy Palmer <palmerjnz at gmail.com> wrote:
> Hi Clayton,
> On Wed, May 2, 2018 at 4:56 AM, Clayton Steneroden <
> claytonsteneroden at planitgeo.com> wrote:
>> I am testing a wfs (in development) against qgis and wanting to know if
>> anyone can cue me in as to whether response paging should just work (qgis
>> v3, wfs v2) when you add a layer exceeding the initial points loaded, or if
>> you need other techniques to load all features from a wfs into qgis as a
>> layer.  I see posts over past years on earlier versions that say response
>> paging does not work in QGIS, one should instead change settings so the
>> layer loads new points based on the bbox, things like that.
> Yes from QGIS 2.18 WFS paging should work with WFS 2.0 services. Give QGIS
> 2.18 to ensure it works with your service. Note QGIS 3.0 has a few WFS
> issues and bugs that need to be resolved, so I don't recommending using
> that version yet.
> Cheers
> Jeremy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180501/76c2b4c9/attachment.html>
