[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Stefan Steiger Steiger at cor-management.ch
Wed Feb 6 07:28:39 PST 2019
Is it not possible to create two official repositories ?
One for "all-platforms", one for "dirty/fishy/phony/dubious/in-progress"
-----Ursprüngliche Nachricht-----
Von: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Im Auftrag von Martin Dobias
Gesendet: Mittwoch, 6. Februar 2019 15:50
An: Paolo Cavallini <cavallini at faunalia.it>
Cc: qgis-dev <qgis-developer at lists.osgeo.org>
Betreff: Re: [QGIS-Developer] Windows only version of a QGIS 2.18x plugin
On Wed, Feb 6, 2019 at 12:04 PM Paolo Cavallini <cavallini at faunalia.it> wrote:
> On 06/02/19 09:42, Richard Duivenvoorde wrote:
> > If you prefer to put it in QGIS repo: just add a big note in the
> > metadata.txt description that this plugin is only usable with vesper
> > and windows. And maybe do an OS check in the __init__ for illiterate
> > users ;-)
> I respectfully disagree with that: at the very core of the QGIS
> project it stands the idea of letting everybody use the best possible
> GIS, without discrimination. This kind of approach would in fact
> favour Windows users.
My preference would be to keep the official QGIS plugin repo more open and allow plugins that do not support all QGIS platforms. Often there are useful tools that are only available for one platform and plugin author does not have power to change that. But we should not make life of users on the supported platform more complicated just because other platforms cannot be supported.
As it was suggested already, if there would be a larger amount of plugins that are not multi-platform, we could have a piece of metadata so that users on other platforms could be warned.
For example, Crayfish plugin for QGIS 2.x did not support macOS - it was a known limitation and it would be sad if the plugin would be rejected from the official QGIS plugin repo just because of that.
Cheers
Martin
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
