[QGIS-Developer] Why is .qgz the default format?
DelazJ
delazj at gmail.com
Mon Jan 21 05:07:15 PST 2019
Hi all,
No, Andreas, you are not alone. I was planning to write to the list for the
same reason. thanks.
I'm not sure how many users rely on qgd data yet, but I find it annoying
when using a simple and basic project to have it in qgz format by default
(and losing the so good "find and replace" in text editor).
Could we imagine to use by default the qgs format and when the user
connects to auxiliary data or anything that needs a qgd file, to propose to
either switch to qgz format or save the qgd file along?
Regards,
Harrissou
Le lun. 21 janv. 2019 à 13:59, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi QGIS devs,
> Am I the only QGIS user that finds it a bit annoying that .qgz is now the
> default format instead of .qgs (plain text format)?
> I really often look into the .qgs files, or I create scripts that process
> them or find and replace stuff in text editor.
> Now I always have to unzip first and then zip again. Quite annoying.
> Couldn't we switch back to .qgs as default?
> Or if the switch back to .qgs is no option - couldn't we introduce a new
> global option that allows me to set my prefered way of storing .qgs files?
> Zipped or unzipped?
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190121/4ea62c8a/attachment.html>
