[QGIS-Developer] Why is .qgz the default format?
Régis Haubourg
regis.haubourg at gmail.com
Mon Jan 21 07:14:58 PST 2019
Ok thanks René Luc,
so we have three issues to solve. That's not something that deserves
killing qgz by itself. Let's push that into the bugfix run.
Régis
Le lun. 21 janv. 2019 à 16:13, René-Luc Dhont <rldhont at gmail.com> a écrit :
> On windows, the user with an accent in the account name can create the
> project as a QGZ file but can't save the updated project as a QGZ file.
> In the list provided by Paolo,
> https://issues.qgis.org/projects/qgis/issues?category_id=35&set_filter=1&sort=id%3Adesc&status_id=o&subproject_id=%21%2A
> , a number of issues deriving from accent and qgz file:
> * all layers gone when reopen *.qgZ as User „Jörn“
> * Project which are saved with special characters in the filename and with
> the qgz extension are blank
> * Special Characters in Project-Names saved as Qgz-Files do not work /qgz
> as default
> René-Luc
> Le 21/01/2019 à 16:04, Régis Haubourg a écrit :
> Hi René-Luc,
> What issues did you face during training? I'm afraid we won't improve if
> we advice to workaround this feature .
> Régis
> Le lun. 21 janv. 2019 à 16:00, René-Luc Dhont <rldhont at gmail.com> a
> écrit :
>> Hi all,
>> During training, I discourage to use .qgz and auxiliary storage. I force
>> users to save project as .qgs to avoid issues.
>> It is not stable yet for me.
>> René-Luc
>> Le 21/01/2019 à 15:54, Paolo Cavallini a écrit :
>> > Hi all,
>> > On 21/01/19 14:40, Hugo Mercier wrote:
>> >> I would vote for your 3rd proposition: replace xml hacking by something
>> >> that looks like calls to an API.
>> >> And adding an option for those who want to switch back to .qgs +
>> >> separated aux files, keeping the default to .qgz.
>> > moreover, there are a number of issues deriving fom the qgz files, see
>> > All the best.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190121/153a80ea/attachment.html>
