[QGIS-Developer] QGIS Server and native Processing algorithms
David Marteau
dmarteau at 3liz.com
Wed Jul 10 00:49:26 PDT 2019
> Le 10 juil. 2019 à 08:44, Alessandro Pasotti <apasotti at gmail.com> a écrit :
> did you call QgsApplication.processingRegistry().addProvider(QgsNativeAlgorithms()) ?
You may need to call the above, before calling 'Processing.initialize()'
> On Wed, Jul 10, 2019 at 8:42 AM Alexander Bruy <alexander.bruy at gmail.com <mailto:alexander.bruy at gmail.com>> wrote:
> Hi,
> I need to access Processing algorithms from the QGIS Server plugin.
> But any attempt to call any Processing algorithm failed with following
> error message in
> the logs
> CRITICAL Processing[2960]: Error: Algorithm native:clip not found
> In the same time I can access analysis classes like QgsHillshadeFilter
> or QgsZonalStatistics.
> Is it possible to access Processing algorithms from server plugins?
> Thanks
> Alexander Bruy
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it/>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190710/9466c6a6/attachment.html>
