[QGIS-Developer] QGIS Server and native Processing algorithms
Alexander Bruy alexander.bruy at gmail.com
Wed Jul 10 01:18:53 PDT 2019
I have Processing initialization code in my plugin. Looks like local issue
as on another machine same code works fine.
Thanks and sorry for the noise.
ср, 10 лип. 2019 о 10:49 David Marteau <dmarteau at 3liz.com> пише:
> Le 10 juil. 2019 à 08:44, Alessandro Pasotti <apasotti at gmail.com> a écrit :
> did you call QgsApplication.processingRegistry().addProvider(QgsNativeAlgorithms()) ?
> You may need to call the above, before calling  'Processing.initialize()'
> On Wed, Jul 10, 2019 at 8:42 AM Alexander Bruy <alexander.bruy at gmail.com> wrote:
>> Hi,
>> I need to access Processing algorithms from the QGIS Server plugin.
>> But any attempt to call any Processing algorithm failed with following
>> error message in
>> the logs
>> CRITICAL Processing[2960]: Error: Algorithm native:clip not found
>> In the same time I can access analysis classes like QgsHillshadeFilter
>> or QgsZonalStatistics.
>> Is it possible to access Processing algorithms from server plugins?
>> Thanks
>> Alexander Bruy
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3:   www.itopen.it
Alexander Bruy
More information about the QGIS-Developer mailing list
