[QGIS-Developer] Bummer... not working geopackage & QGIS
Alessandro Pasotti apasotti at gmail.com
Thu Jul 11 07:23:32 PDT 2019
On Thu, Jul 11, 2019 at 3:03 PM Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Hi Richard,
> On 10/07/19 20:03, Richard Duivenvoorde wrote:
> > Hi Devs,
> > may I draw ones attention to this (in my view pretty serious) issue:
> > https://github.com/qgis/QGIS/issues/28914
> > Showing off QGIS in combination with a geopackage failed today,
> > because 'it just does *NOT* work' :-)
> > Wanted to create an issue and then found the above one
> > (which is a duplicate of #29035, #29166, #29766  etc)
> > So added a test dataset to the issue.
> > The 'Move selection on top' in the attribute table is broken for already
> > some versions of QGIS. Not sure about others, but I often show this to
> > newbies, to find their selected features.
> > I think this kind of basic functionality should not be broken for such a
> > long time in our beloved QGIS is it?
> thanks a lot for the report. I'm also surprised, as I assumed this basic
> functionality was covered by tests. Should we invest more in adding
> tests in this area?
Test on the GUI are very very limited, and they are also quite hard to
write and to maintain.
If you add that the attribute table code has been crying for a serious
refactory since 2.x you know why it's broken (again).
But yes, we should invest more in the tests AND in the refactoring of the
code, the problem IMO with the attribute table is that it would be a *huge*
effort.
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190711/689b171b/attachment.html>
More information about the QGIS-Developer mailing list
