[QGIS-Developer] Bummer... not working geopackage & QGIS
Nyall Dawson nyall.dawson at gmail.com
Sun Jul 14 16:58:53 PDT 2019
On Fri, 12 Jul 2019 at 00:24, Alessandro Pasotti <apasotti at gmail.com> wrote:
> On Thu, Jul 11, 2019 at 3:03 PM Paolo Cavallini <cavallini at faunalia.it> wrote:
>> Hi Richard,
>> On 10/07/19 20:03, Richard Duivenvoorde wrote:
>> > Hi Devs,
>> > may I draw ones attention to this (in my view pretty serious) issue:
>> > https://github.com/qgis/QGIS/issues/28914
>> > Showing off QGIS in combination with a geopackage failed today,
>> > because 'it just does *NOT* work' :-)
>> > Wanted to create an issue and then found the above one
>> > (which is a duplicate of #29035, #29166, #29766  etc)
>> > So added a test dataset to the issue.
>> > The 'Move selection on top' in the attribute table is broken for already
>> > some versions of QGIS. Not sure about others, but I often show this to
>> > newbies, to find their selected features.
>> > I think this kind of basic functionality should not be broken for such a
>> > long time in our beloved QGIS is it?
>> thanks a lot for the report. I'm also surprised, as I assumed this basic
>> functionality was covered by tests. Should we invest more in adding
>> tests in this area?
> Test on the GUI are very very limited, and they are also quite hard to write and to maintain.
> If you add that the attribute table code has been crying for a serious refactory since 2.x you know why it's broken (again).
> But yes, we should invest more in the tests AND in the refactoring of the code, the problem IMO with the attribute table is that it would be a *huge* effort.
Also (it's not defence, but...) I seem to recall this particular bug
popping up in various forms since forever. Someone will post a
(partial?) fix, and then a month later the bug will be bug (maybe in
another form?). In any case, I very much doubt this is a 3.x
regression, rather just some piece of fragile code which was
sticky-taped together in the first place, and that sticky-tape keeps
coming undone.
Unfortunately (and I hate to give bad news like this), but I'm with
Alessandro here. Attribute table is the most fragile code left in
modern QGIS versions. It's inefficient, difficult to debug, constantly
regressing, and the code is a nightmare mix of interdependent circular
signals. The code is honestly horrible to work with, which is another
reason I suspect attribute table bugs are "overlooked" during bug
fixing sprints...
Nyall
More information about the QGIS-Developer mailing list
