[QGIS-Developer] Bummer... not working geopackage & QGIS
Paolo Cavallini cavallini at faunalia.it
Sun Jul 14 18:01:59 PDT 2019
Hi Nyall, all,
so you're implicitly suggesting refactoring this code entirely, right?
I imagine this would be a major effort. Does anybody have an idea of the order of magnitude of the work involved?
Regards.
On 15 July 2019 01:58:53 CEST, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>On Fri, 12 Jul 2019 at 00:24, Alessandro Pasotti <apasotti at gmail.com>
>wrote:
>> On Thu, Jul 11, 2019 at 3:03 PM Paolo Cavallini
><cavallini at faunalia.it> wrote:
>>> Hi Richard,
>>> On 10/07/19 20:03, Richard Duivenvoorde wrote:
>>> > Hi Devs,
>>> > may I draw ones attention to this (in my view pretty serious)
>issue:
>>> > https://github.com/qgis/QGIS/issues/28914
>>> > Showing off QGIS in combination with a geopackage failed today,
>>> > because 'it just does *NOT* work' :-)
>>> > Wanted to create an issue and then found the above one
>>> > (which is a duplicate of #29035, #29166, #29766  etc)
>>> > So added a test dataset to the issue.
>>> > The 'Move selection on top' in the attribute table is broken for
>already
>>> > some versions of QGIS. Not sure about others, but I often show
>this to
>>> > newbies, to find their selected features.
>>> > I think this kind of basic functionality should not be broken for
>such a
>>> > long time in our beloved QGIS is it?
>>> thanks a lot for the report. I'm also surprised, as I assumed this
>basic
>>> functionality was covered by tests. Should we invest more in adding
>>> tests in this area?
>> Test on the GUI are very very limited, and they are also quite hard
>to write and to maintain.
>> If you add that the attribute table code has been crying for a
>serious refactory since 2.x you know why it's broken (again).
>> But yes, we should invest more in the tests AND in the refactoring of
>the code, the problem IMO with the attribute table is that it would be
>a *huge* effort.
>Also (it's not defence, but...) I seem to recall this particular bug
>popping up in various forms since forever. Someone will post a
>(partial?) fix, and then a month later the bug will be bug (maybe in
>another form?). In any case, I very much doubt this is a 3.x
>regression, rather just some piece of fragile code which was
>sticky-taped together in the first place, and that sticky-tape keeps
>coming undone.
>Unfortunately (and I hate to give bad news like this), but I'm with
>Alessandro here. Attribute table is the most fragile code left in
>modern QGIS versions. It's inefficient, difficult to debug, constantly
>regressing, and the code is a nightmare mix of interdependent circular
>signals. The code is honestly horrible to work with, which is another
>reason I suspect attribute table bugs are "overlooked" during bug
>fixing sprints...
>Nyall
Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190715/b0dbaf1b/attachment.html>
More information about the QGIS-Developer mailing list
