[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Matthias Kuhn matthias at opengis.ch
Fri Jul 12 13:44:25 PDT 2019
Hi Loïc,
Thanks for the feedback.
Any idea what else could be tried?
Unfortunately I do not have a system where I could quickly try, so I am
out of possibilities and ideas for now ...
Best regards
Matthias
On 7/12/19 9:47 PM, lbartoletti wrote:
> Hi Matthias, Rainer,
> Matthias, I tested but unfortunately I can't reproduce the problem with this
> code. Tested with llvm 6, 7 and 8 on FreeBSD 12 and 13 amd64.
> But, of course :), the problem is still present for QGIS with llvm 8.0.1 on
> FreeBSD 13.
> For information, I created a CI on Cirrus for FreeBSD 12 and here the
> results: https://cirrus-ci.com/task/5576588232491008 and my fork of your
> repository https://github.com/lbartoletti/qmap_initializer_compile_time
> Thanks to take care about this issue.
> Loïc
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
