[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Rainer Hurling
rhurlin at gwdg.de
Sat Jul 13 00:57:12 PDT 2019
Hi Matthias,
sorry for the late answer, but I was busy at work
My skill on C++ and CMAKE are very limited. The following steps should
show, what I did and hopefully understood right:
- create a local directory 'qmap_initializer_compile_time'
- download your files into the dir
- create a second dir 'qmap_initializer_compile_time_BUILD' one level up
- run 'cmake ../qmap_initializer_compile_time' in the latter
(compilation takes only a moment)
-- The CXX compiler identification is Clang 8.0.1
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done
-- Generating done
-- Build files have been written to: ~/qmap_initializer_compile_time_BUILD
- #list -l
-rw-r--r-- 1 rhurlin user - 12186 2019-07-12 20:45:35 CMakeCache.txt
drwxr-xr-x 6 rhurlin user - 512 2019-07-12 20:45:44 CMakeFiles
-rw-r--r-- 1 rhurlin user - 7679 2019-07-12 20:45:35 Makefile
-rw-r--r-- 1 rhurlin user - 1409 2019-07-12 20:45:35
cmake_install.cmake
-rwxr-xr-x 1 rhurlin user - 533248 2019-07-12 20:45:44
drwxr-xr-x 3 rhurlin user - 512 2019-07-12 20:45:38
qmap_initializer_compile_time_autogen
- Do I have to run ./qmap_initializer_compile_time after this (?)
- How long do I have to wait then ... (?)
I suspect, that my last steps are inappropriate to get the compile time
of QMap? I could use some help here ...
Rainer
Am 12.07.19 um 07:54 schrieb Matthias Kuhn:
> Hi Rainer,
> There has been a question for a minimal example to reproduce the problem
> on the bugreport.
> I have come up with
> https://github.com/m-kuhn/qmap_initializer_compile_time but don't easily
> have an environment available to reproduce the problem. Are you able to
> verify the issue with the code before, so it can confidently attached to
> the issue?
> Thanks
> Matthias
> On 7/6/19 8:52 AM, Rainer Hurling wrote:
>> Hi Matthias,
>> Thanks for keeping this up.
>> It sounds like OSX hits the same problem with LLVM 8.0.0.
>> Rainer
>> Am 05.07.19 um 10:45 schrieb Matthias Kuhn:
>>> FYI,
>>> An upstream bug has been closed on Qt side
>>> https://bugreports.qt.io/browse/QTBUG-57672
>>> I didn't find a matching one on LLVM side so I opened one
>>> https://bugs.llvm.org/show_bug.cgi?id=42515
>>> Matthias
>>> On 6/26/19 11:50 AM, Loïc Bartoletti wrote:
>>>> Hi rainer,
>>>> Le 26/06/2019 à 11:23, Rainer Hurling a écrit :
>>>>>> - can you try with llvm 6 or 7 from ports (I think that FreeBSD 13
>>>>>> have llvm 8 by default)?
>>>>> Loïc, this seems to be the right approach. With llvm 8 and 7 the
>>>>> build fails, with llvm 6 all builts fine!
>>>>> As a fallback (workaround), I could enforce the port to use llvm 6,
>>>>> until the real cause is found.
>>>> You should fill an issue to our bugzilla. Maybe llvm or core dev can
>>>> take a look at this bug? AFAIK, Ed found already an error (not
>>>> reproduced?) in FreeBSD devel with newest llvm version.
>>>>> The problem seems to be with
>>>>> src/core/qgscoordinatereferencesystem_legacy.h and its long table,
>>>>> handled via QMap. Obviously, newer llvm versions (7 and 8) are not
>>>>> able to create the code correctly.
>>>> I'll test with newer llvm version but on FreeBSD 12.
>>>> It doesn't seem to affect Linux, since Docker is based on Ubuntu 19.04
>>>> and clang 8 if I'm not mistaken. Nyall, Denis, can you confirm?
>>>> Regards
>>>> Loïc
