[QGIS-Developer] Crashes on exit
Andreas Neumann
a.neumann at carto.net
Wed Jul 17 23:35:09 PDT 2019
Hi Nyall,
Thanks for the reply. I also experienced quite a lot of these crashes.
Something that often shows up in the stack trace is
proj_lpz_dist :
proj_lpz_dist :
QgsCoordinateTransform::transformPolygon :
QgsCoordinateTransform::QgsCoordinateTransform :
QHashData::free_helper :
QgsCoordinateTransform::addToCache :
QgsCoordinateTransform::invalidateCache :
QgsApplication::exitQgis :
QgisApp::~QgisApp :
CPLStringList::operator char * __ptr64 * __ptr64 :
main :
BaseThreadInitThunk :
RtlUserThreadStart :
Like in https://github.com/qgis/QGIS/issues/30753
But I am sure you also came across these.
Really annoying. Perhaps disabling the crash reporter on QGIS exit on
the release versions would help? Can we enable them just on the master?
Andreas
On 2019-07-18 08:19, Nyall Dawson wrote:
> On Thu, 18 Jul 2019 at 16:05, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi QGIS core devs,
>> Currently on the Github issues I have the (subjective) feeling that every third report is about QGIS crashing on closing the program. It seems to be a really wide-spread issue that a majority of our users have. It would be great for QGIS' reputation if we could fix this/these issue(s). Or has this already been fixed and people don't use the newest versions?
> These are VERY frustrating. It's actually a bunch of different
> underlying issues causing this. We've probably squashed a dozen or so,
> but they keep resurfacing (or being re-introduced), and none of the
> existing bug reports have clues on remaining causes.
> Fortunately they are harmless. Mathieu has previously suggested we
> just shut down the crash reporter on QGIS exit to avoid this -- I
> think that would be a worthwhile change.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190718/8314ff43/attachment.html>
