[QGIS-Developer] Crashes on exit
Mathieu Pellerin nirvn.asia at gmail.com
Wed Jul 17 23:44:07 PDT 2019
While discussing this further with Nathan, disabling the crash reporter
might not be the right solution as it'd most likely bring the OS crash
dialog anyways.
We'd need for the crash reporter to detect specific traces and silently
fail when it detects a useless / harmless trace.
There's also the problem of ppl pasting wrong traces due to not having
installed the debug package, we could improve the notification in this
scenario to suggest installing package.
On Thu, Jul 18, 2019, 13:35 Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Nyall,
> Thanks for the reply. I also experienced quite a lot of these crashes.
> Something that often shows up in the stack trace is
> proj_lpz_dist :
> proj_lpz_dist :
> QgsCoordinateTransform::transformPolygon :
> QgsCoordinateTransform::QgsCoordinateTransform :
> QHashData::free_helper :
> QgsCoordinateTransform::addToCache :
> QgsCoordinateTransform::invalidateCache :
> QgsApplication::exitQgis :
> QgisApp::~QgisApp :
> CPLStringList::operator char * __ptr64 * __ptr64 :
> main :
> BaseThreadInitThunk :
> RtlUserThreadStart :
> Like in https://github.com/qgis/QGIS/issues/30753
> But I am sure you also came across these.
> Really annoying. Perhaps disabling the crash reporter on QGIS exit on the
> release versions would help? Can we enable them just on the master?
> Andreas
> On 2019-07-18 08:19, Nyall Dawson wrote:
> On Thu, 18 Jul 2019 at 16:05, Andreas Neumann <a.neumann at carto.net>
> wrote:
> Hi QGIS core devs,
> Currently on the Github issues I have the (subjective) feeling that every
> third report is about QGIS crashing on closing the program. It seems to be
> a really wide-spread issue that a majority of our users have. It would be
> great for QGIS' reputation if we could fix this/these issue(s). Or has this
> already been fixed and people don't use the newest versions?
> These are VERY frustrating. It's actually a bunch of different
> underlying issues causing this. We've probably squashed a dozen or so,
> but they keep resurfacing (or being re-introduced), and none of the
> existing bug reports have clues on remaining causes.
> Fortunately they are harmless. Mathieu has previously suggested we
> just shut down the crash reporter on QGIS exit to avoid this -- I
> think that would be a worthwhile change.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190718/0cb5e610/attachment.html>
More information about the QGIS-Developer mailing list
