[QGIS-Developer] QGIS and MSSQL Spatial
Alexander Bruy
alexander.bruy at gmail.com
Sat Jul 20 00:14:25 PDT 2019
Ah, before testing connection one should get list of the databases.
Quite confusing and not coherent with all other database providers.
Sorry for the noise.
сб, 20 лип. 2019 о 09:52 Alexander Bruy <alexander.bruy at gmail.com> пише:
> Hi,
> I'm trying to connect to the MSSQL server with QGIS native MSSQL provider
> on Windows. Database server uses standard port, TCP/IP access is enabled.
> After specifying connection name, host and username/password and pressing
> "Test connection" button I get an error
> Error opening connection : Driver not loaded Driver not loaded
> On other hand if I setup a system DSN using same parameters and
> specify DSN instead of the host in the QGIS connections dialog
> everything works.
> Am I miss something or native MSSQL provider works only with ODBC even
> on Windows?
> Alexander Bruy
Alexander Bruy
