[QGIS-Developer] DBManager save querys only saves selected code - Bug or Feature?
Matthias Kuhn
matthias at opengis.ch
Sun Jul 21 01:29:21 PDT 2019
Is there any other software with this behavior to "save only selected"?
Or a use case where this is desirable?
From top of my mind I can't find anything and I think all our other
editors always save the full text, regardless of selection.
Regards
Matthias
On 7/21/19 10:19 AM, Alexandre Neto wrote:
> I agree that it can be a feature, but needs to be more explicit to the
> user.
> My problem is that I was creating several instructions and running
> them one by one. Then, in the end, I wanted to save everything and
> didn't realize that there was a selection.
> Documentation alone won't be enough IMHO. So, maybe a check box with
> "Save selected only?
> Anyway, thanks for making saving available.
> Alex
> A Sáb, 20/07/2019, 18:27, Loïc Bartoletti <lbartoletti at tuxfamily.org
> <mailto:lbartoletti at tuxfamily.org>> escreveu:
> Hi Alexandre,
> It's my bad, I used _getSqlQuery
> <https://github.com/lbartoletti/QGIS/blob/master/python/plugins/db_manager/dlg_sql_window.py#L557>
> insted of self.editSql.text().
> For me a feature must be documented and for this one the user must
> have the choice between the full text or the selected part. So
> it's a bug or I add this option and the doc.
> Regards,
> Loïc
> Le 20/07/2019 à 17:04, Alexandre Neto a écrit :
>> Hi,
>> I had some frustrations with the DB Manager save query
>> functionality. At some point I finally understood that, if there
>> is some selected code, only that part is saved.
>> To me it's weird, because when you save, the rest of the code is
>> maintained in the SQL editor, and the name of the query is
>> showned in the topo.
>> But, when I turn of my project and open it again, surprise
>> surprise, only the selected part is in the Query.
>> Bug or feature?
>> Alex Neto
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190721/f95216f2/attachment.html>
