[QGIS-Developer] DBManager save querys only saves selected code - Bug or Feature?
Alexandre Neto senhor.neto at gmail.com
Sun Jul 21 01:19:27 PDT 2019
I agree that it can be a feature, but needs to be more explicit to the user.
My problem is that I was creating several instructions and running them one
by one. Then, in the end, I wanted to save everything and didn't realize
that there was a selection.
Documentation alone won't be enough IMHO. So, maybe a check box with "Save
selected only?
Anyway, thanks for making saving available.
Alex
A Sáb, 20/07/2019, 18:27, Loïc Bartoletti <lbartoletti at tuxfamily.org>
escreveu:
> Hi Alexandre,
> It's my bad, I used _getSqlQuery
> <https://github.com/lbartoletti/QGIS/blob/master/python/plugins/db_manager/dlg_sql_window.py#L557>
> insted of self.editSql.text().
> For me a feature must be documented and for this one the user must have
> the choice between the full text or the selected part. So it's a bug or I
> add this option and the doc.
> Regards,
> Loïc
> Le 20/07/2019 à 17:04, Alexandre Neto a écrit :
> Hi,
> I had some frustrations with the DB Manager save query functionality. At
> some point I finally understood that, if there is some selected code, only
> that part is saved.
> To me it's weird, because when you save, the rest of the code is
> maintained in the SQL editor, and the name of the query is showned in the
> topo.
> But, when I turn of my project and open it again, surprise surprise, only
> the selected part is in the Query.
> Bug or feature?
> Alex Neto
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190721/c40297e7/attachment.html>
More information about the QGIS-Developer mailing list
