[QGIS-Developer] QGIS shortcuts on windows. With and without grass
Sylvain POULAIN sylvain.poulain at giscan.com
Mon Jul 22 21:43:36 PDT 2019
Just my opinion and report from some users : these two shortcuts are
confused. Most users, until they know what is Grass, doesn't understand why
there is two icons ...
In Linux, there is only one shortcut and we could enable or disable grass
plugin so why two shortcut in Windows. I know Windows interface have
redundancy but why doing the same counter intuitive thing in Qgis shortcuts
Regards,
Le jeu. 11 juil. 2019 à 10:32, Jürgen E. Fischer <jef at norbit.de> a écrit :
> Hi Nathan,
> On Thu, 11. Jul 2019 at 15:24:56 +1000, Nathan Woodrow wrote:
> > Just wondering if there is a reason that we have 3 shortcuts to QGIS when
> > you install on Windows.
> > - QGIS
> > - QGIS with Grass
> > - QGIS with Grass 7.6
> GRASS is optional (in OSGeo4W - which is also used for the standalones).
> So
> the first shortcut is from the QGIS package, the third from the grass
> plugin
> package.  Not sure where the second is from - there should only be two.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190723/9fe21c2f/attachment.html>
More information about the QGIS-Developer mailing list
