[QGIS-Developer] PostgreSQL execute and load SQL in Processing Modeler
DelazJ
delazj at gmail.com
Wed Jul 31 10:15:18 PDT 2019
Hi Pedro,
Using "PostgreSQL execute SQL"
https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-sql?
without the load part
Regards,
Harrissou
Le mer. 31 juil. 2019 à 18:31, Pedro Venâncio <pedrongvenancio at gmail.com> a
écrit :
> Dear all,
> I'm developing a Processing Model and I want to run an algorithm (Union)
> on a specific PostGIS layer. The idea is to have this input layer hardcoded
> to the Union algorithm.
> If this layer is stored in a system file (SHP, or any other vector layer
> format), it is simple, just pointing Union input field to that file. But as
> it is stored in PostgreSQL, I thought to use "PostgreSQL execute and load
> SQL" algorithm to call the layer and use it in Model, as input to Union.
> In fact this works well, but when running the Model, the PostGIS layer is
> loaded to QGIS canvas.
> I think this is happening because "PostgreSQL execute and load SQL" won’t
> create any new layer, and load the PostGIS layer itself, as a result of the
> query, just like it's explained in the docs:
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-and-load-sql
> So, anyone have any hint to call a PostGIS layer and use it as hardcoded
> input to a Model algorithm, without python coding?
> Thank you very much!
> Best regards,
> Pedro Venâncio
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190731/feb120ef/attachment.html>
