[QGIS-Developer] PostgreSQL execute and load SQL in Processing Modeler
Pedro Venâncio pedrongvenancio at gmail.com
Wed Jul 31 15:16:25 PDT 2019
Hi Harrissou,
"PostgreSQL execute SQL" can not be input to another algorithm in
Processing Modeler, because it has no output. It is only used to execute
SQL directly in the database.
"PostgreSQL execute and load SQL" do the same, but load the result of the
SQL query in QGIS, and this one already has the possibility to be used as
input in another Modeler algorithm. The problem is just that it is loaded
to QGIS, and my goal is to hardcode a PostGIS layer input to a Modeler
algorithm. This is really easy with system based files, but I can't find an
easy solution to PostGIS layers.
Thanks anyway Harrissou!
Best regards,
Pedro
DelazJ <delazj at gmail.com> escreveu no dia quarta, 31/07/2019 à(s) 18:15:
> Hi Pedro,
> Using "PostgreSQL execute SQL"
> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-sql?
> without the load part
> Regards,
> Harrissou
> Le mer. 31 juil. 2019 à 18:31, Pedro Venâncio <pedrongvenancio at gmail.com>
> a écrit :
>> Dear all,
>> I'm developing a Processing Model and I want to run an algorithm (Union)
>> on a specific PostGIS layer. The idea is to have this input layer hardcoded
>> to the Union algorithm.
>> If this layer is stored in a system file (SHP, or any other vector layer
>> format), it is simple, just pointing Union input field to that file. But as
>> it is stored in PostgreSQL, I thought to use "PostgreSQL execute and load
>> SQL" algorithm to call the layer and use it in Model, as input to Union.
>> In fact this works well, but when running the Model, the PostGIS layer is
>> loaded to QGIS canvas.
>> I think this is happening because "PostgreSQL execute and load SQL" won’t
>> create any new layer, and load the PostGIS layer itself, as a result of the
>> query, just like it's explained in the docs:
>> https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-and-load-sql
>> So, anyone have any hint to call a PostGIS layer and use it as hardcoded
>> input to a Model algorithm, without python coding?
>> Thank you very much!
>> Best regards,
>> Pedro Venâncio
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190731/5e9500a7/attachment.html>
More information about the QGIS-Developer mailing list
