[QGIS-Developer] QGIS Server 2.x and caching question
René-Luc Dhont rldhont at gmail.com
Wed Jun 12 02:09:53 PDT 2019
Hi Andreas,
We didn't yet find shadow layers in QGIS 3, but I don't think it has
been fixed because it's a silent issue for desktop users.
Regards,
René-Luc
Le 12/06/2019 à 11:01, Andreas Neumann a écrit :
> Hi René-Luc,
> Thanks for the reply. Good to know that we are not the only ones
> struggling with such issues.
> Is this known issue in QGIS 2.x only or also in QGIS 3.x?
> I will also have a look at the Layer Board plugin and see what it does
> and how it could help us.
> Thanks,
> Andreas
> On 2019-06-12 10:02, René-Luc Dhont wrote:
>> Hi Andreas,
>> It's a known issue. It is not easy to understand because it's due to
>> SHADOW layers...
>> Some times, QGIS keeps some undisplayed layers with the same UUID and
>> stored it in the QGIS project.
>> You can use Layer Board plugin to remove them.
>> Regards,
>> René-Luc
>> Le 11/06/2019 à 18:28, Andreas Neumann a écrit :
>>> Hi all,
>>> At my new work place we are running a 2.x QGIS server which in two
>>> projects behaves very strange: sometimes colors display in the color
>>> we expected, sometimes really light. Then my colleagues discovered
>>> that more than rules share the same UUID identifier, because the QGS
>>> files have been copy pasted into a anew project and then aggregated
>>> again into the same single project.
>>> Not knowing about the internals of QGIS server 2x (and 3x) I wonder
>>> if this something we need to avoid? Are the UUID identifiers of a
>>> symbology rule relevant and absolutely need to be unique? Do we have
>>> to avoid such id clashes?
>>> The "human readable" nature of qgs/qml files naturally seduce people
>>> to copy / paste and mix project stuff together in text editors ...
>>> Thank you for your feedback on this topic.
>>> Andreas
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190612/73590d5d/attachment.html>
More information about the QGIS-Developer mailing list
